manual overdrive help please
Old Oct 7, 2011 | 12:38 AM
affliction1's Avatar
Car: 89 chevy camaro rs
could someone give me detailed instructions on how to wire my od on my 700r4 up to a toggle,ive been looking all night and every one i find isnt detailed enough and there confusing
Old Oct 7, 2011 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: manual overdrive help please
It's not the overdrive, it's the torque converter clutch.
https://www.thirdgen.org/torqueswitch
Old Oct 7, 2011 | 01:09 AM
sorry should have added i dont have an ecm my car is stright carb,just wanna be able to flip a switch at like 55 and lock the converter
Old Oct 7, 2011 | 10:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Doesn't make a difference as long as the wiring isn't hacked up.
Old Oct 7, 2011 | 10:20 AM
doesnt have any of the previous wiring,just dont know how to wire it,i do not have an aldl i was going to run 12 volts,to trans and ground thru toggle just not sure how to tho
Old Oct 8, 2011 | 12:32 AM
bump please help
Old Oct 8, 2011 | 01:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
+12V to pin A on the TCC connector, ground to pin D
Old Oct 8, 2011 | 01:56 AM
thanks=]
now which is (a) and which is (d)
Old Oct 8, 2011 | 02:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The letters are cast into the plastic on weather pack connectors.
Old Oct 8, 2011 | 07:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Can set it up to lockup automatically in 4th without a switch
http://purplesagetradingpost.com/sum...o/700R4p2.html
Old Oct 8, 2011 | 11:40 PM
do you have a pic of the weatherpack connector,to show me which is which please,i dont wanna drop the trans down to write it down
Old Oct 9, 2011 | 02:39 PM
there not cast into it i looked everwhere,i cant seem to find the letters do you have the order?
Old Oct 10, 2011 | 12:00 AM
bump
Old Oct 11, 2011 | 12:37 AM
ive tryed connecting the positive and neg every which way and theres only one way i get any power,and it imideiately pop the fuse,any idea why
Old Jan 26, 2012 | 11:53 AM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I'm also looking to due the samething, any suggestions out there?
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
