need help changing the rear end gear ratio
Old Oct 24, 2011 | 07:07 PM
nhslacrosse2's Avatar
Car: 1991 z28
Axle/Gears: 2.77 posi
i have a 1991 z28 with a 305 and a t5. i have discovered that the car was not always a manual and still has the 2.77 rear in the car. i would like to change the gearing to 3.73. i am not opposed to replacing the entire rear if i can find one cheap enough but i would like to just replace the internals to achieve the 3.73 posi. my rear end is already posi and im not sure what i need to replace. i found this on ebay and im not sure if this is all i need. any advice would be appreciated, thanks
this is a link to what i think i need
http://www.ebay.com/itm/Chevy-8-5-Re...item1c20178b39
Old Oct 24, 2011 | 07:28 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: need help changing the rear end gear ratio
I want to follow this one and see too...
Old Oct 24, 2011 | 09:04 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
That is NOT the correct gear set!!! That's for an 8.5" 10-bolt., you have a 7.5" 10-bolt. This is what you're looking for:
http://www.summitracing.com/parts/RM...73OE/?rtype=10
Old Oct 25, 2011 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Gear ratio bang for the buck? You bet. That said, I have an acquaintance with a modified L69, T-5, and 3.73's. He laments that after stopping at a light, he's forced to shift into second before he's through the intersection.
JamesC
Old Oct 25, 2011 | 08:18 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Not the correct gear set (8.5 10-bolt). With the 2:77 rato you have a BW 9-bolt with a 7.750 dia ring gear. Also changing gear sets with this 2-series 9-bolt means you are SOL. So change the complete rear assemly.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
