transmission
Old Oct 29, 2011 | 12:40 AM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
transmission
Ever since my car has bein heating up, my tranny feels sluggish. here are some of the issues I have. incorect timing, something is up with the MAF , put new radiator still over heats, tstat is new. could someone school me on my 88 tpi iroc?
Thanx in advance.
Old Oct 29, 2011 | 06:39 AM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
Re: transmission
How does the air dam look underneath the car? Do the cooling fans come on?
Old Oct 29, 2011 | 06:48 AM
saldav420's Avatar
Transmission: 700r
Re: transmission
Air dam is not complete, and fan runs constant.
Old Oct 30, 2011 | 09:11 AM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Re: transmission
Lack of an air dam will cause cooling issues at speed, car needs it to create the low pressure behind the radiator, and draw the air through. It's been a while, so I may be wrong, but if the car is moving at >35mph, the ecu won't kick on the cooling fans. If it's overheating when sitting still, and the cooling fans are running, you probably have much larger issues.
Old Oct 30, 2011 | 01:42 PM
saldav420's Avatar
Transmission: 700r
Re: transmission
Going to check tstat, I put back the air dam and it's still getting hot.
Old Oct 31, 2011 | 12:53 AM
Stebo's Avatar
Car: 1992 RS Camaro
Engine: 305 soon to be 383
Transmission: Richmond -6
Axle/Gears: 4:10 with Auburn locker
Re: transmission
Are you losing coolant ? If so determine where. May be a simple fix or a more serious problem with heads or head gaskets. As stated above the air dam is vital in keeping the engine cool. Is the radiator clean, good circulation etc ? Good luck !
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
