700r4 rev limit?
Old Nov 6, 2011 | 07:27 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
700r4 rev limit?
i have an 84 camaro z28, with a 355 s.b.c., flat top pistons, edelbrock performer intake, carb, cam, and lifter set. my timing is set at 10*, and i have the stock rearend. the tranny was rebuilt, has transgo shift kit, upgraded vane, new sprag input, sunshell gear, and corvette servo.
the issue im having is when im at wotitll shift threw the gears fine, but as soon as third comes and the rpms are about 5500 the tranny "revs" out and doesnt gain any speed just rpms. what would cause that? i have it in the D position...am i pushing to much power for the trans? i think the rear gears are either a 3.08 or 3.23 gears with limited slip posi. not sure if govenor was matched to shift kit or not when built. any ideas?
Old Nov 6, 2011 | 11:40 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 700r4 rev limit?
Your detent cable could be out of adjustment or the 3-4 clutch pack is toast.
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
