TV Cable Adjustment (Picture Included)
Car: 1991 Camaro Z28
Engine: 5.7L
Following advice posted throughout the forum, I decided to attempt to adjust my TV cable tonight. Reason for this is between 2-3 and 3-4 the transmission slips a bit; that is, the engine revs as if in neutral between those gears. This is really noticeable when getting on it a bit.
First, I made sure that the pedal moved the throttle as much as I could with my hand. Then to adjust, I pressed in the D and the cable housing moved forward quite a bit while holding the throttle wide open. I then pressed (towards the windshield) the cable housing as far as I possibly could. Lastly, I sat in the car and depressed the gas pedal to the floor. The attached picture is where it ended. Does this look right?
Car is blocked in driveway tonight so I will test drive tomorrow.
Engine: 4++,350 & 305 CIs
Re: TV Cable Adjustment (Picture Included)
They are all a lil bit different.. thats y the adjustment is there.
sounds like you need a rebuild.
Engine: 5.7L
Interesting, I've read a lot of threads saying it sounds like an adjustment was needed.
What should I expect to observe if the adjustment I made is not correct?
Usually if a TV cable needs adjusted the transmission would be shifting at incorrect intervals, taking too long to shift, etc.
The clutch between 2 & 3 and 3 & 4 is shot. I'm not an expert myself, so keep searching, but imo I believe a rebuild is in your future.
Engine: 5.7L
Got it, thanks for the advice guys. Now hopefully I didn't cause worse problems with the adjustment of the cable. LOL
Yesterday, I posted the instructions from the Service Manual, and a link to a Youtube video showing two correct ways to adjust the TV cable...
https://www.thirdgen.org/forums/post...077-post7.html
From the sounds of it, your transmission probably needs a rebuild. TV cable position doesn't cause slipping, it just causes the transmission to shift at the wrong times with harder/softer shifts then it should.
9192camaro
16
Feb 3, 2019 12:21 AM
Street Lethal
Aug 12, 2015 11:33 AM
