Aluminum driveshaft help
Old Nov 11, 2011 | 12:35 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Hello I was wondering if anyone could help me i was wondering if a 1996 v6 driveshaft was Aluminum and if it would fit as a replacement for mine i know 4th gen ones fit but wasnt sure if this one would and was still aluminum. Thank you
Old Nov 11, 2011 | 07:26 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: Aluminum driveshaft help
I believe they might've been 2pc steel driveshafts in the v6 but not 100% on that.
Old Dec 1, 2011 | 10:47 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Yes they were 2 piece drive shafts and they sucked. I had one. There was a center support bearing that liked to wear out. I replace mine with a one piece V8 ds.
Old Dec 2, 2011 | 01:06 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I never seen a two piece driveshaft on a camaro
Old Dec 2, 2011 | 02:04 AM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
I don't know why they are two pieced...but I was told by this guy who balanced drive lines it's because of the length.
Old Dec 2, 2011 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since the V6 and V8 shafts are interchangeable, length wouldn't seem to be an issue. The OE JG1 shaft is approximately 41 1/2" from U-joint center to U-joint center and 47 1/2" with slip yoke.
The two-piece drive shaft is seen in fourthgen V6 cars.
JamesC
Old Dec 4, 2011 | 04:59 AM
RocketyMan's Avatar
Seems kinda bogus to me. Makes putting in your vsux drive line like a job living up to its name; a little squirrely.
Wonder why they make it a two piece then...
Old Dec 4, 2011 | 07:53 AM
JamesC's Avatar
From what I've 'read' the two-piece helped quell vibration issues in V6 cars.
JamesC
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
