ticking when motor is off, what can it be
Old Nov 19, 2011 | 10:03 PM
SLING-BLADE's Avatar
this has been going on for a little while now. after the motor has been ran ( or even just turned over ) i get a ticking sound from the motor. im led to believe that it might be coming from one of my double valve springs on the driver side, but i cant be sure. after it has been ran and turned off every 2 - 8 seconds i get a semi loud popping sound that seems to come from under my valve cover. a while back i had my valve cover off when i was installing a new intake manifold and i noticed that one of my valve spring/rockers had a little more play than the others did, i havnt got to fixing that yet so that might be the problem. (questions and picture below) my rockers have 2 nuts holding them down
-what would be making the ticking/popping?
-if it is the valve spring how do i fix??
-if it isnt my valve THEN WHAT IS IT???
Old Nov 19, 2011 | 10:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: ticking when motor is off, what can it be
Sounds kinda like lifter bleed down. normal.
And maybe post this in the correct section will get better and more responses
hydrolic144
Sep 8, 2015 06:55 PM
db057
Sep 4, 2015 07:57 AM
mike_c
Aug 27, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
