T-5 versus T-56?
Old Nov 20, 2011 | 05:05 PM
basiccamaro's Avatar
T-5 versus T-56?
I've always heard that the stock T-5 five speed transmission is not as strong as the T-56 six speed. But if you were going to rebuild a T-5, are there aftermarket parts that would make it stronger?
Also, what are the gear ratios of each gear of the T-5? Is first gear lower on the T-56?
Old Nov 20, 2011 | 05:13 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: T-5 versus T-56?
Check out g-force transmissions for a stronger t5
From what I understand, the main advantage of the t56, other than being stronger, is the 6yh gear is am ultra deep 2nd overdrive. Giving you lower rpms on the highway
Old Nov 20, 2011 | 05:44 PM
Pocket's Avatar
Car: 91 Trans Am
Sums it up nicely
Weak point of the T5 is the case and G-force sells a stronger replacement along with practically everything else for it. Even after you're done with all those upgrades you can buy a built up T56 that will take twice the tq
Old Nov 20, 2011 | 05:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The counter to mainshaft distance, bearing designs and case design (even aftermarket) keep that from happening.
Run the T5. Go T56 when it breaks.
tonys91rs
Oct 10, 2015 03:31 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
