700r4 slips at takeoff under WOT
Old Nov 25, 2011 | 09:42 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Axle/Gears: 3.42 w/posi & disc brake
Hey guys,
Im having trouble with the tranny and im clueless as to what it might be...
first off, it shifts hard and high into 2 and 3 under light throttle even after i adjusted my tv... I was thinking maybe it had to do with the new 3.42 gears so i thought nothing of it... so tonight at the track when the light turned green i floored it and it stuttered and then just rev'ed to 4k like it was in neutral... I figuered that my carb wasnt perfectly tuned and I went for a second run but this time i took it abit easier than before... It did the same s*** again, run after run... I just doesnt do anything if u go wot from 0 mph
Ive searched on google and I read somewhere that it could be a pressure leak... I want to know what the tranny experts on here think...
Old Nov 26, 2011 | 08:00 AM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Re: 700r4 slips at takeoff under WOT
Anyone???
Old Nov 26, 2011 | 08:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Welcome to the trans needs a rebuild club!!!
(Most likely)
Old Nov 27, 2011 | 01:45 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I concur. T-56 time!
Old Nov 27, 2011 | 01:54 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
When mine did that the cause was the (aftermarket
converted)torque converter blew it's thrust bearing and
plugged passages in the tranny's oil circuits with little
filings-had to drop the tranny,take it apart,muck out all
the particles,check the pump,and put the tranny back
together with a good torque converter and reinstall-has
been fine since
There are other possible causes for the slippage too...
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
