Speedo Cable Calibration
Car: 1986 Pontiac Firebird T/A
Engine: 350 Small Block
Transmission: T5 5spd. Manual
Hey, my dads got an 86 T/A that we bought off a guy who swapped the motor for a worked 350SBC from a 5.0 305. Some of the mods that are done to the motor are:
Some sort of cam, pretty decent size.
Edelbrock intake and 650cfm 4bbl carb.
Vortec heads.
A/C delete.
Electric cooling fan.
Headers into true dual exhaust, no cats, i think 3 inch but might be 2.5.
The car is a 5 speed with T-tops and very, very fun to drive! Im not sure if its original 5 speed but as far as i know it is, just havent done any researching on the vin or anything. Its def not showroom condition and needs some cosmetic work, but its very mechanically sound. Ill have to get some pics of it up..
But anyway, thats besides the point of this thread lol The PO put a 3.73 gear set in the 10 bolt rearend, and remember its got the T5 5spd manual trans on an 86 model Firebird Trans Am. He disconnected the speedometer cable bc the speedo was off after changin the gears so the car was racking up miles faster than it should be. How do i calibrate the speedometer so its correct again? Any info would help. Thanks!
Vortec heads.
A/C delete.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Cable Calibration
Welcome to TGO, KYM. As most questions have been asked and answered, a search is generally a good idea.
Verify what drive and driven gears are in the trans. You may well need both, though my guess is that only the latter will be required. The following will provide the info you need for 3.73's:
https://www.thirdgen.org/forums/tran...ve-driven.html
BTW, the parts--gears, gear housing, retainer--can be purchased separately from the following site (look at TH350) at a considerable savings over Hawks; for example, the gears are only $7.00 per. Loading will take a sec.
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
JamesC
JamesC
JamesC
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
