tv adjustment cable question
Old Nov 29, 2011 | 11:40 AM
1roc89z28's Avatar
i did the tv cable adjustment for the 700r. i have a 91 z l98. and it feels better at shifts. but in the post that ive fallowed, it reads like this 1-2…………………15-20 MPH
2-3…………………25-30 MPH
3-4…………………40-45 MPH
but in my car it goes to 2nd at 10 mph, then to 3rd at 20. so it seems to be shifting faster then recommenations. also when i have trottle at WOT. should the tv line feel hard? or feel free at close and WOT? dont want to burn my transmission.
Old Nov 29, 2011 | 12:07 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: tv adjustment cable question
You push down on the self ratchet pull in cable till flush.. then WOT the cable will adjust itself
Old Nov 29, 2011 | 01:25 PM
1roc89z28's Avatar
yes everything is done. but this is what im left whit. at WOT should the cable feel realy resistant?
Old Nov 29, 2011 | 01:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yes, did you/shop install a new trans? maybe you/shop didnt get the cable hooked into the trans properly.
Old Nov 29, 2011 | 02:19 PM
88gta3508's Avatar
Engine: 231 / 383
Yes @ WOT it should be resistant... That's how the self adjustment works
When its @ idle you can feel the spring tension from the trans correct???
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
