2.56 gears
2.56 gears
I found some 7.5 gears with the 2.56 ratio in a 91 Caprice that we want to put in a 1984 Camaro housing that was originaly a 3.23.
By eye everything looks the same ,has anyone ever done this and know that I can do this swap.
I know I have to use the 2 series carrier that is in the caprice but I just want assurance that the housing will work.
Thanks in advance.... Kevin
Car: `86 SS / `87 SS
Re: 2.56 gears
If the 91 Caprice is a 7.5/7.625 with 28 spline axles, you'll need axles from a later third-gen.
Re: 2.56 gears
thanks for the quick replies...
No I doubt anyone has ever done that. .....lol
I should explain why...it's a circle track dirt car
with a 350 turbo you run in second gear with 4.10's
with 2.56's you can run in 1st gear
__________________
__________________
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 2.56 gears
UltRoadWarrior9
Sep 2, 2015 08:24 PM
