Rear Gear Speed
Old Dec 5, 2011 | 11:09 AM
LoudTransAm's Avatar
Car: 1987 Trans Am GTA
Engine: TPI 350
Axle/Gears: 9 bolt From An Aussie
Rear Gear Speed
So i finally had the car on the highway and above 60 mph. Well around 65 mph my rpms in OD are about 17-1800. Dosnt seem normal to me. Thinking maybe the previous order did a rear gear swap? I figured I could easily be 80+ and not be that high in the rpms in OD?
Old Dec 5, 2011 | 11:18 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Rear Gear Speed
I've got 3.23 and 2k rpm is 65 so you've probably got 2.7something.
Old Dec 5, 2011 | 11:21 AM
Engine: TPI 350
Re: Rear Gear Speed
Well I plan to drive home to Orlando soon and drive the trans am but I dont want to be doing 70ish with 3-3500rpms all the way there, thats burnin gas and pretty hard on the engine!
Old Dec 5, 2011 | 12:25 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: Rear Gear Speed
i have 3.42's and i run 2000 rpm at 81 mph.
it all depends on you final transmission gear ratio
Old Dec 5, 2011 | 01:02 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Re: Rear Gear Speed
Easy solution, slow down to 65. You'll get there around the same time. Only a min or two difference.
Old Dec 5, 2011 | 01:52 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Rear Gear Speed
According to your numbers at about 2700 rpm you'd be doing over 90 mph. What do you expect? That sounds pretty normal.
Old Dec 5, 2011 | 03:48 PM
Engine: TPI 350
Re: Rear Gear Speed
I expected better number but I guess the car would be decent for drag racing on stock gears and trans. Always stays up in the needed rpm range to make power. Ill find out come spring when I get back up to Arkansas and take the T/A to the strip
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
