9 bolt rear-end disc brake question
Old Dec 19, 2011 | 04:09 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
I bought an 86 Camaro with a 9 bolt in it, the left rear brake caliper has a slow fluid leak. I do not know what year and model of car the rear end came out of, when I go to get a caliper repair kit am I going to have a problem? Does anyone know if all 9 bolt rear-ends use the same brake calipers? I will probably remove the caliper and take it to the parts store with me unless someone knows that they are all the same.
Old Dec 19, 2011 | 05:37 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
Re: 9 bolt rear-end disc brake question
I believe all rear disc cars up to 1988 used the same caliper. In 1989 they changed to an aluminum caliper, so I quess its a question of what you have an iron or aluminum caliper rear end.
Old Dec 20, 2011 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
On the money. If you're uncertain which you have, check my vbGarage (little shedlike icon next to my online status) for a pic of the 89+ alum PBR version with 11.7" rotors. If yours doesn't look the same, then you have the 88- iron Delco-Moraine version with 10.5" rotors--which, of course, you should have if the rear is original to your car.
JamesC
Old Dec 20, 2011 | 12:25 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
Ok, will check when I get a chance, I know the rear end has borg warner stamped under the center section.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
