T56 fastener torque specs
Old Dec 20, 2011 | 08:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I last did this a few years ago, cant remember what the specs are and I cant find the sheet I wrote it on. I probably put it aside somewhere where I wouldn't lose it. I only have an 82-92 shop manual, if I need to I will go buy a 4th gen one, but I was hoping someone else had one handy.
Anyone know how tight I need the flywheel and pressure plate bolts?
And isnt there some place on the the pressure plate or clutch fork where I need to apply some grease?
Old Dec 20, 2011 | 08:23 PM
Re: T56 fastener torque specs
Torque goes with fastener size.
Flywheel bolts should be in the 60-70 ft-lbs range, clutch bolts around 35.
Put grease wherever moving parts rub against each other... a SMALL amount (emphasis on SMALL) on the clutch splines, some on the throwout groove, some on the clutch fork pivot, plenty in the pilot.
Old Dec 21, 2011 | 01:16 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Depends on which T56.
If it's an LT1 T56 "pull" pressure plate, those are 22 or 25lb-ft which isn't typical for 3/8 coarse thread.
Any other "push" clutch, you can google based on the thread size.
You can put a tiny amount of grease at the disc hub - to - input shaft area. Don't over-do it.
Any fork pivot location is good to grease. Lightly coat the throwout bearing tube also. Don't put enough that it might get flung into the clutch.
Bohemian
Aug 15, 2017 05:11 PM
Nervous2
Oct 8, 2015 10:53 PM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
angel2794
Sep 8, 2015 06:22 PM
