How to know the gear ratio
Car: 1992 RS 25th anniversary
Engine: 5.0
Transmission: 700
Axle/Gears: 99 Z28 rear axle 3.23
just to know the gear ratio of a rear axle, I´m going to change the differential from a 92 Camaro rs, I´m gonna mount a 98 z28 differential, so the stock ratio is 2.73, and I don´t know how the check in the new differential the ratio, Can anybody help me please, thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How to know the gear ratio
Remove the cover and count the teeth on the ring and the pinion. Any swap requires new oil anyway.
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Or an easier way...remove the diff cover and look for the stamping on the RING gear. You might have to remove some grease to see it clearly, but it's there.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the 10-Bolt FAQ sticky above for ring and pinion numbers and their gear ratios.
JamesC
JamesC
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
The easiest way is NOT to the remove the cover....
The easiest way is to determine whether or not it's posi....
If it is posi, both wheels will spin the same way when you turn the rear wheel.
If they move in opposite directions, the posi is blown, or is an open-diff.
If it's posi, turn one wheel, one full revolution (360 deg), and count approx how many times the drive shaft spins. 3 spins (almost even) most likely is 3.08, 3 and 1/4 spin is approx 3.23, etc.
If it's not a posi, (open dif) then spin the wheel two times, and count the number of driveshaft rotations.
This method is far less messy, less time consuming and best of all free. It will give you the approximate gear ratio, and assuming we are talking about stock gearsets, anyone should be able to tell what they have.
One cannot argue though, that although this method's accuracy is solely based on the person, counting the teeth on the pinion/ring gear is the most 100% accurate way. There is just much more involved.
Engine: 5.0
Transmission: 700
thanks everyone for your answers, I´m very thankfull to all of you.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
