i need help
Car: 1986 Camaro Iroc-z
Engine: V-8 5.0L TPI (being replaced)
i need help
ok first off ive never rebuilt a car, never even really messed around other than basic maintenance.
im starting off with the rear axle and suspension, its all ripped out right now. i do not have a posi differential, currently in the process of getting one. does the gear ratio have to be specific to match the trans/eng at all? now i understand the higher the ratio the higher the TQ and overall a faster rotation. ive just never done this before and i dont know. i may sound really dumb, but whatever. any advice will help. thanks.
also im located by temecula, ca if anyone wants to help or needs help.
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: i need help
To answer your question, NO it has nothing to do with each other. Now, to ask you a question: What are you wanting to do with the car? What tranny are you working with and what engine?
Car: `86 SS / `87 SS
Re: i need help
The higher in the rpm range power is made, the more likely a higher rear gear will benefit the combo.
The transmission has bearing on it too. The 700R4 has a high first gear and doesn't need as much rear gear.
If you're sticking with the TPI intake, 3.42 is probably the highest rear gear your car will benefit from.
Re: i need help
as of right now the plan is to get a 350 bored piston bigger cam witha supercharger. ive got a good friend with an engine shop the races trucks so hes building all that for me. as far as trans not to sure havent really looked into it cuz i know thats going to be a while before i get some money for the eng and trans. any suggestions? and thanks for the help.
