t56 swap
Old May 1, 2012 | 03:33 PM
  #51
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
Re: t56 swap
Slave cylinder, and input shaft is different LT1 to LS1.
So, which one do 3rd gens use, or does it matter.....
Old May 1, 2012 | 03:36 PM
  #52
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: t56 swap
93-97 T56's are compatible. You can change a 98+ to be a 94-97 T56 if you buy the appropriate parts.
93 T56 is very expensive to change up to a 98+ for an LS1 swap. Requires quite a bit more changes.
Expensive enough that if I ever go to swap a Gen3/4 engine into my car I'll likely be selling my T56 to buy a LS1 T56.
Old May 1, 2012 | 04:50 PM
  #53
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: t56 swap
With the 93-97 T56 the bell housing bolts up as well as the stock LT1 flywheel if you have a motor with the one piece rear main seal. Otherwise you need the centerforce 2pc rr seal flywheel for the LT1 clutch.
Old May 1, 2012 | 06:33 PM
  #54
Car: 1985 Trans Am
Re: t56 swap
Now...next ???.....I have long tube headers, I heard that they will not work with a 5-6 speed....does anyone know if this is true......
Old May 3, 2012 | 06:57 PM
  #55
Car: 1985 Trans Am
Re: t56 swap
^^^^Anyone....Anyone.....
Old May 3, 2012 | 07:19 PM
  #56
Re: t56 swap
They work just fine. Get the Hawks double hump X-member and you can even reclaim ground clearance if you have a custom Y-pipe built.
Old May 3, 2012 | 08:15 PM
  #57
Car: 1985 Trans Am
Re: t56 swap
^^^Thanks....Im glad to finally to clear that up......And im running duel pipes....
Old May 7, 2012 | 12:26 PM
  #58
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: t56 swap
Glad I found this, I just bought a t56, and i hope to gather the parts and have it in sometime next month.
For the VSS for me, I JUST sent my tail housing out to alloy to get it machined for a mechanical speedo. I have just heard too many times that the converter box does not register the speed correctly.
I CANT wait to be banin gears in the Iroc!
Old May 7, 2012 | 12:30 PM
  #59
Re: t56 swap
Converter box works perfectly once its wired up correctly and calibrated correctly.
Old May 7, 2012 | 03:19 PM
  #60
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: t56 swap
I think most people get confused when setting up the SGI boxes as there are many different configurations and the instructions are not that great. But once you get it set it works great.
Old May 7, 2012 | 04:00 PM
  #61
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Re: t56 swap
I was actually talking about that black box that converts the electrical vss output to a cable for the mechanical speedos.
Old May 7, 2012 | 04:01 PM
  #62
LilSki's Avatar
Car: 85 Trans Am
Re: t56 swap
Oh gotcha. Yeah I wouldn't trust something like that.
Old May 7, 2012 | 06:13 PM
  #63
87350IROC's Avatar
Car: 87' IROC
Re: t56 swap
Excellent. You are doing it right.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
