transmission cooler placement
Old Jan 13, 2012 | 04:11 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i currently have a large B&M cooler in front of my radiator and behind intercooler but i want to move it somewhere else. Last summer the car was running a bit warm past the point htat i like so i am trying to bring temps down. Where is a good place to put it? could i mount it on the firewall where the heater box used to be and put a fan on it? i am trying to get some photos or ideas on where to mount it. I do not have much room under the hood becuase of all the turbo related stuff
Old Jan 13, 2012 | 04:54 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: transmission cooler placement
I don't know for certain, but this pic appears to show that the rear cooler that is obvious, is plumbed to the Auto tranny.
Old Jan 13, 2012 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you intend to put a fan on it, anywhere you can make it fit will do fine. Mine is currently under the passenger side floor but I intend to move it to the back of the car this winter. Just like it's mounted at the front, use hard lines as much as possible.
The only real reason to have it at the front blocking the rad is airflow. Mounting it under the car or at the back doesn't get the airflow but a simple fan will fix that.
Old Jan 17, 2012 | 02:29 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Not as clean as I wanted the bay to look for these photos but I had the plastic off so I took these .Thats a 12.5 x 17in. Derale Cooler with a 12in. fan that is set to stock temp for back up while a 16in. front pusher fan is set to key on.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
apie2546
Sep 20, 2015 01:03 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
