BW 9 bolt rearend
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
BW 9 bolt rearend
Looks to me like we need a sticky for those of us with these differentials. I have one in both my '88 & '89 GTA's. I am currently putting an LS1 in my '89 and was wondering about my differential and if it will be strong enough to handle the power of the new engine. I had it checked out by my mechanic and he said everything was fine with it. I think he only replaced one bearing that was marginally questionable. I had him install the bearing cap ARP studs & a girdle cover while he was at it. He said the posi worked good too. I am assuming around 460hp at the flywheel of the new engine. I looked at my options for a 9", 12 bolt or S60, but they are quite expensive and I wasn't real fond of the brake selection available for those rearends. So, I want to keep my 9 bolt. I just don't know what the weak points of the rearend are. Will it be fine like it is? Anything on it I should upgrade to help it survive?
BTW, I did do a search and found a few helpful threads, but most dealt with the posi unit shims. And there are over 800 pages in this category. So I haven't had time to go through all of them. If this information has already been covered, please just give me a link. Thanks for the help guys.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: BW 9 bolt rearend
Here's a sticky:
https://www.thirdgen.org/forums/afte...er-9-bolt.html
Here's one that could be:
https://www.thirdgen.org/forums/faq-...now-about.html
Perhaps you've perused both, but they might be helpful to others.
JamesC
JamesC
Engine: cammed LS1
Thanks. I have seen these threads before now that you mention it. I guess I just wasn't looking in the right place for the sticky.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
