3.42 std. to 3.73 posi. How to?
Old Feb 4, 2012 | 12:38 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
OK, I think it's time to upgrade by gears! I have to drop the tank to change the fuel pump and this will be the perfect time to upgrade to a 3.73. posi (since I have to drop the rear end anyways)!
I currently have the stock 3.42 std. gears (non-posi) that came with my 85 IROC.
I hoping to be able to use the same axles, rea end and just change out the guts in the diffirential. I have enough know how to tear it all apart and put it back together, just need some help or suggestions on what parts I need to replace, gear, pinion, etc.??
I am not opposed to keeping the 3.42 either if there is a way to make it posi, limited slip... The car seems to like that ratio too.
Old Feb 4, 2012 | 12:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 3.42 std. to 3.73 posi. How to?
You'll replace everything but the axles and the housing.
Not exactly a bolt-in, setting up gears requires some measurement and alignment work.
Old Feb 4, 2012 | 07:29 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
if you can find a 26 axle spline posi from a 3.42 or 3.73 rearend it will bolt in and use all your stuff.https://www.thirdgen.org/forums/tran...-10-bolts.html
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
