T-56, Spec stage 3 clutch and FW, Jegster TA, reverse chatter
Old Feb 9, 2012 | 12:47 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Combo as stated. In forward gears, no chatter. When I put it in reverse, it will shake the fillings out of your teeth! Any ideas?
Old Feb 9, 2012 | 01:01 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56, Spec stage 3 clutch and FW, Jegster TA, reverse chatter
Triple check all the mounting parts for the transmission and torque arm.
The stage 3 could be a quick-engaging part of the issue.
But you should be able to bring the rpm up and ease up on the pedal unless something else is loose.
Old Feb 19, 2012 | 11:10 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Hey can you have severe chatter if you do not give enough RPM's? I seem to have some and other times not, I think it my be me letting clutch out too fast and not enough throttle
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
tonys91rs
Oct 10, 2015 03:31 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
