TH 200 and 700R4??
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
TH 200 and 700R4??
I have Q about this.
I saw a shifter I like.
The box says
TH 200.
It comes with a cable.
So I looked up TH 200. It has OD like a 700R4.
I saw the physical dimensions are a tad different, as are the gearing ratios.
Both being automatic, and 4 speed, would it work?
Thank You For Any Info!!!
The box says
TH 200.
Car: check
Engine: check
Transmission: check
Re: TH 200 and 700R4??
The box says
TH 200.
The box says
TH 200.
The OD version of it is the 200-4R transmission.
That being said I have no idea if the shifter will work with the 700R4 transmission.
RBob.
Car: '87 Camaro
Thank You for the education!
The box says TH 200.
I don't know why the site I went to has TH 200 being an OD.
I googled What is a TH 200 transmission. That's why I was asking.
So a 200R4 is the OD. The 4 being the tell- tell?
Thanks again!
Thanks again!
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
