Not compression braking?
Old Feb 15, 2012 | 09:50 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Yet another issue... The 700 isn't compression braking when the shifter is in OD... Thoughts?
Old Feb 15, 2012 | 10:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Not compression braking?
It's not supposed to.
Old Feb 15, 2012 | 11:47 AM
87350IROC's Avatar
Car: 87' IROC
Agreed. You aren't going to get much compression braking in OD anyway unless you are going really fast. In OD it is always going to the choose the highest gear rather than compression braking.
Old Feb 15, 2012 | 11:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well no, in OD the input sprag allows the input shaft to overrun so there's no engine braking, but in manual 3rd and below the overrun clutch locks up the input shaft.
Old Feb 15, 2012 | 11:59 AM
87350IROC's Avatar
Car: 87' IROC
I seem to recall getting engine braking at higher rpm in OD (130mph +). But it could just be the wind resistance at that speed. It has been a while.
Either way, problem is now solved with the T56,
Old Feb 16, 2012 | 10:11 AM
Car: 1988 Iroc-Z
Ok, other than that , I'm getting a "shutter" VERY badly (only happened 3x so far) when the tranny is at 2500-3000 in second and i smash on the go-juice pedal... I'm thinking that its the shifter b/t gears... only other thing I think it could be is line pressure but since its only happened a few times, I really dont think that is the issue
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
