1986 iroc 700R4 shift problems
Old Feb 19, 2012 | 04:01 AM
speedfreak1967's Avatar
ok just changed tranny due to slipping, and new tranny is acting just like the one i took out heres how it acts when you take off in drive you hit the gas rpm goes up then slams into gear and slips but if you put in 1st it takes off like it should then shift into 2nd and acts normal then shift into drive and rpm goes up and tranny does nothing so i shift into OD and rpm goes up a little then takes off like it should and if you let off gas then hit gas again the rpm goes up then takes off like it should, and the tranny i just took out did the exact same thing, tranny is full of fluid and it doesnt smell burnt the iroc has a 305 tpi with 700r4 no mods., any help would be appriciated
Old Feb 19, 2012 | 09:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1986 iroc 700R4 shift problems
TV cable connected and properly adjusted? Proper fluid level in transmission?
And welcome to TGO... Best 3rd gen f-body tech site on the web.
RBob.
Old Feb 19, 2012 | 01:06 PM
tv cable is hooked up not shure if i adjusted it properly, fluid level is dead on full
Old Feb 19, 2012 | 01:08 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Definitely sounds like mis-adjusted TV cable
Old Feb 19, 2012 | 01:34 PM
ok ill try and adjust the tv cable and see what happens, thanks
Old Feb 19, 2012 | 01:41 PM
Don't try. Do it right or you'll cook the tranny. There's really good info on here about TV cable adjustment.
Old Feb 19, 2012 | 01:48 PM
Read this
http://www.tvmadeez.com/article/index.php
Steven 86IROC-Z
May 24, 2026 04:52 AM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
