9 bolt posi opened up (with pictures)...DAMAGE...is it still good?
Old Feb 25, 2012 | 01:12 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have been hearing a slight whining from my rear end since the end of last season so today i had a chance to yank the cover off and take a peek. There was metal in the gear oil (bad!) and i saw that the posi cones were both bottomed out (source of metal). So i yanked the axles and pulled the center chunk out and dissassebled the posi again to see what i was up against. Now note ive reshimmed this posi about 3-4 years ago now. This is what i found:
Note the wear on the walls of the actual case. Im not so concerned about the cones since those are wear items but the case has some unusual wear. Is this thing toast and should i be hunting for a new case or can i just scuff it up...throw some new cones in it and be done with it for awhile again?
Old Feb 25, 2012 | 01:24 PM
Twin_Turbo's Avatar
Re: 9 bolt posi opened up (with pictures)...DAMAGE...is it still good?
I'd run it, no prob. The scrapes in the wall are from trash, or chips off the cones most likely.
Old Feb 25, 2012 | 01:41 PM
subroc's Avatar
Engine: 355 TPI
yea thats what i figured they were from. Ok then now its off to get some new cones.
Old Feb 25, 2012 | 01:46 PM
Twin_Turbo's Avatar
You say you shimmed them, but did you mill them down? Looks like nothing was taken off the end.
I do mine like this and then shim them
Old Feb 25, 2012 | 01:50 PM
subroc's Avatar
Engine: 355 TPI
yea they were milled off 3-4 years ago but look like nothing was taken off again. When assembled it before there was clearance but it quickly got eaten away.
Old Feb 25, 2012 | 03:22 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
There was an Aussi supplier for 9-bolt stuff awhile back thru Flea-Bay: " street_and_strip_gears " is the username . He's got nothing listed right now but you could contact them thru that site to see if they still have anything.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Linson
Aug 21, 2015 02:12 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
