shifts at 5mph
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
shifts at 5mph
from complete stop it shifts at 5mph. i set tv cable by book and the wot method.then it shifts again at 20mph then at 40.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: shifts at 5mph
Doesn't sound too bad if it's under light load. How does it behave under a heavier load?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: shifts at 5mph
Upshifts are based on throttle position & vacuum combined so the shift points varies under varying driving conditions.
Axle/Gears: '01 3.42 10 bolt
Re: shifts at 5mph
I'm taking it, there's some "history" here?
As in, it's not like last night when you parked it it was perfectly fine, but today, you walk out to th ecar and hop in to go to work and all the sudden out of the clear blue without any warning whatsoever it's now LIKE THIS?
Eh???
What happened to it in between when it worked right, and now? More specifically, what was done to it?
Incidentally, Jeff is exactly right; the 700 uses ONLY TV cable and governor (road speed) inputs to determine when to shift. No hint of vacuum is involved.
Eh???
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: shifts at 5mph
no its been like this. but i came across a piece on this site that sed it shouldnt be shifting til its gets 15-20 mph.
Re: shifts at 5mph
Then if the TV cable is right, it needs a governor recalibration kit.
http://www.transmissioncenter.org/70...t.htm#Governor for example
darwinprice
17
Oct 11, 2015 11:51 PM
