T56 Master Cylinder Rod Doesn't Reach the Peg on the Clutch Pedal. What's up?
Old Mar 16, 2012 | 12:01 PM
V8SC1987's Avatar
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
So I'm working on installing my ls1/t56 into my 87 camaro, and something just doesn't seem right with the pedals/clutch master cylinder. One question I have is what is supposed to stop the 4th gen clutch pedal when it comes up? Right now I have the Switch for the cruise out of the pedals and the pedal comes all the way up and hits the mounting bracket for the switch with the pedals out of the car. When the pedals are mounted in the car the pedal hits the bracket under the dash that the steering column bolts to... is that common because I haven't heard of that one before?
Also when the pedals are in the car the clutch master cylinder rod is about a 1/4" short from reaching the peg on the clutch pedal even though the pedal is sitting on the bracket under the dash the the steering column bolts to. The only way I can get the rod on the peg is if I push the pedal in some but that doesn't seem right... I'm really at a loss for what is going on here.
Old Mar 16, 2012 | 12:58 PM
87350IROC's Avatar
Car: 87' IROC
Re: T56 Master Cylinder Rod Doesn't Reach the Peg on the Clutch Pedal. What's up?
What pedals are you using?
What clutch master cylinder are you using?
Old Mar 16, 2012 | 01:10 PM
V8SC1987's Avatar
I am running 4th gen pedals with the gas pedal bracket cut off. I'm also running a 4th gen clutch master cylinder. Maybe the clutch switch for cruise is the pedal stop? With that switch out and the pedal coming all the way up to the bracket that the switch mounts to the rod wouldn't reach the peg even when both were out of the car.
When I pull the clutch pedal back enough so the rod will go on the peg though it seems like there's some tension in the spring.
Old Mar 16, 2012 | 01:18 PM
87350IROC's Avatar
Car: 87' IROC
I am also running 4th gen pedals but with a 4th gen Tick Performance master cylinder.
In my case, the neutral safety switch is what prevents upward motion of the pedal. But in actuality, once the rod is connected, the master will restrain the motion as well.
I forgot about the spring. Most people remove the clutch assist spring. My dad's vette has the spring as well and I don't like it. I removed mine before I installed the pedals. So I can't help you there.
Old Mar 16, 2012 | 02:05 PM
V8SC1987's Avatar
Yeah if I pull the pedal back to hook up the rod then the rod will be my stop unless it bottoms out on that switch first. I thought the switch up at the top was for there for dropping the cruise off when you press the clutch pedal in and the neutral safety switch is when the pedal is on the floor.
I just was afraid if I pulled the pedal back to hook the rod on there it could affect how the clutch disengages from the flywheel. I guess not knowing exactly what is supposed to stop the pedal from coming on up wasn't helping.
Old Mar 16, 2012 | 03:04 PM
87350IROC's Avatar
Car: 87' IROC
Yup you are right. My memory is poor.
Either way the rod is what controls the upward motion of the pedal and you adjust the cruise switch to suit.
Maybe someone else can comment on the spring, like I said I never ran mine.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
