v6 vs v8 transmission
Ok I have a 1988 chevy camaro with a 2.8l v6 in it and I am swapping it out with a 5.0l v8 out of a 1986 camaro. I am wondering if I am able to use the same flywheel and clutch and trans from my v6 to put with my v8. It seems to me the bell housing bolt pattern is the same.
Re: v6 vs v8 transmission
The 6-cyl disc has a different # of splines (14) and will not work with a V8 transmission which has 26.
No.
Flywheel bolt pattern to the crank is different; bell housing bolt pattern is different; trans is weenie.
If you're gonna do a V8 swap, throw the 6-cyl stuff in the trash and do a V8 swap.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
bell, bellhousing, body, camaro, clutches, engine, gen, housing, pattern, swap, tranmissiln, trans, transmission, v6, v8
