700r4 overdrive shudder?
Old Mar 22, 2012 | 09:02 PM
eddie79's Avatar
Car: 91 Camaro RS
Engine: 355
Transmission: 700R4 RAPTOR
Axle/Gears: 373
Ive gotta 355 alotta mods done to it, w/ holley 750 ultra dp. my trans is a raptor 700r4 by PATC, w/ a Hughes 3000 stall lockup. its built w/ billet& hardened parts. its all new, shifts fine BUT after its in ovrdrive & i let off the gas it shudders until either i slow down w/ brakes or gas it,then it quits. I can pull it back in third let off gas an it doesnt do it. any ideas please.
Also is there a way to check tcc lock up wire, should it be 12v all time or?
Old Mar 23, 2012 | 12:13 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: 700r4 overdrive shudder?
Yup, mine did the exact same thing. Never found the problem, it was slipping in 2nd gear so I got rid of it.
Old Mar 23, 2012 | 12:49 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
The torque converter will do that is the lockup clutch disc,they sale Dr.tranny shutter fix.
Old Mar 24, 2012 | 10:25 PM
eddie79's Avatar
Car: 91 Camaro RS
Engine: 355
Axle/Gears: 373
I'm not sure. today i put a derales tranns cooler in it, ran a hot wire to tc lock up wire. it stays hot all time unless i hit the brake. so thats workin rite. 13.9v. Idid notice that it didnt happen all the time just everynow & then. thinkin this could be a slite lean condtion. also Im using msd pro billet dist w/out vac adv. use to but long story short. that would help gas but would it fix this? i guess i'll try the shutter fix lol forgot to flare trans line about 5 quarts in the street!
mcfastestZ28
Oct 5, 2015 07:12 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
