rear end help?
Old Mar 23, 2012 | 01:08 PM
Fred meredith's Avatar
Car: 91 Z28
Engine: 350TPI
Transmission: 700R IThink
Axle/Gears: 323
rear end help?
can u put a fourth gen third member in a third gen housing,same ring gear size
Old Mar 23, 2012 | 05:07 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: rear end help?
I just asked that a week ago. As lond as they are both 10 bolts then you can. However you will need the 90 - 92 third gen 10 bolt 28 spline axles. Also the whole rear will need to be checked for lash and proper contact pattern. This is normally best left for a pro. Bearings need to be pressed on and off and need an install kit for shims and crush sleeve.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
