When should 700r4 shift into OD at WOT?
Old Mar 24, 2012 | 01:39 PM
IanT720's Avatar
I have an 85 Trans am with 350 carb and 700r4, when I floor it it starts to redline in 3rd and won't shift into od unless I back off, then if I get on it it will downshift again, I adjusted the tv cable but that helped with the other gears since OD is electric right? So what speed should I be going before I can get into OD at full throttle? Thanks just curios, fluid is perfect and everything thanksE
Old Mar 24, 2012 | 01:47 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: When should 700r4 shift into OD at WOT?
You need to modify your trans to fix that problem. Do a quick search for your answer.
Old Mar 24, 2012 | 02:03 PM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
most wont stock
Old Mar 24, 2012 | 02:10 PM
IanT720's Avatar
Oh I see, thanks
Old Mar 24, 2012 | 02:19 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
http://www.bulkpart.com/2/product/4L...s/A74741B.html
Pac J
May 17, 2020 10:44 AM
Damon
Sep 26, 2015 04:29 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
