Need a new clutch and need advice!
Old Mar 21, 2012 | 10:10 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
So the clutch in my 86 finally took a dump. After 7 years, two motors and two flywheels and three different transmissions the clutch is slipping at 3k and up when the car is hot.
Anyways its time to replace my beloved that has served me well. I currently have a centerforce dual friction stage 2 clutch kit and a cheapo flywheel (which im thinking in the cause of the slippage).
I foresee another motor in the future (350 or lsx) so im not sure i want to put the centerforce back in the car and spend $300 on the clutch kit and then put a new motor/trans in that wont work but at the same time I think the money will be going towards a house instead of a new motor to replace a perfectly fine running motor with 3500 miles on it.
Although its going to cost more than I want to spend I think im going to put the same clutch back in with a billet steel flywheel. I figure that combination will hold up to a few track runs and some 'rear tire durability tests'. I only want to replace it once not several times because of a stock replacement clutch that cant hold for crap.
so im just looking for some input and any other recommendations on flywheels/clutch kits you guys are running.
Oh and currently the car has 305 w/ heads, cam, exhaust, soon to be computer tune, tpi, 3.27 posi 9 bolt, t5
thanks!
Old Mar 22, 2012 | 05:16 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Need a new clutch and need advice!
Im running a stock lightweight flywheel (2 piece rms) with a ram HD clutch kit. Its holding up awesome behind my high compression 355 tpi. Not sure that will be any less expensive than the centerforce clutch you are thinking of running again.
Old Mar 24, 2012 | 05:11 PM
nascar2496's Avatar
Engine: 305 tpi
ok thanks! anyone else?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
