tranny problems need help
Old Mar 24, 2012 | 12:08 AM
tj86cam's Avatar
Car: 1986 camaro
Engine: 96 chev 350 vortec
today i switched out the filter and replaced gasket and fluid. dropped 2 qts in then started car kept stationary and moved through gears while adding more. dip stick says its full. the tranny is shifting hard while kept stationary and while driving. anyone have any ideas what the problem could be?
Old Mar 24, 2012 | 07:48 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: tranny problems need help
Did you check the modulator hose on the trans. Maybe it was knocked off while changing filter.
Old Mar 24, 2012 | 02:23 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
How many qts of fuild did you use It should have been 4 qts
Old Mar 24, 2012 | 04:22 PM
Edwardgp's Avatar
Engine: 454-350
Let us know whats going on we might be able to help.
Old Mar 24, 2012 | 08:57 PM
tj86cam's Avatar
Car: 1986 camaro
im pretty sure the hose is still connected, but ill double check tomorrow after work. put 4 qts in and still called for more so i added 1 more.
this car has been sitting for 10 years or so, bought it off a family member right after he took out the stock 305 and dropped a 350 in.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
