4l60-E questions
Old Mar 30, 2012 | 10:38 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
4l60-E questions
anyways, i have one sitting around, is it better than the 700R4 in my firebird?
would it be worth putting it in?
if so anything special id need to do?
(also its just sitting around because i bought it for the 1998 camaro i had but never swapped them because the old one turned out to still be good, and i also traded it for the firebird)
Old Mar 31, 2012 | 04:35 PM
KuroNeko's Avatar
Re: 4l60-E questions
anyone? im starting to lose intrest and might sell it
Old Mar 31, 2012 | 05:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
How do you plan on controlling the 4L60-E?
Old Mar 31, 2012 | 05:58 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
They're controlled by a computer rather than by a tv cable. Usually that computer is the same computer that would control a newer car's engine. A thirdgen ecm cant control it, so unless you're also doing an ls swap, you'd need to buy a standalone controller, and the cheapest one I've seen is about $600.
Depending on whether or not it was made pre or post 96ish, it might not even bolt on without some expensive adapters.
Old Mar 31, 2012 | 09:53 PM
KuroNeko's Avatar
ok, its going then, i dont need it
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
