Flywheel question
Old Apr 3, 2012 | 08:54 PM
Cerridius's Avatar
Car: 1988 Camaro sport coupe
Engine: 305 TBI
Transmission: T5 world class manual transmission
Axle/Gears: i think its 3.08 ration posi
Flywheel question
Hey everyone, I just have a quick question about flywheel.
I need a flywheel for a 1987 1 piece rear main seal externally balanced (87 383sbc) that will work with a 94 lt1 T56.
Won't a flywheel from a lt1 fit a 87 1 piece because they are pretty much the same? Just as long as I get a 153 tooth external balanced t56 flywheel?
Old Apr 4, 2012 | 12:06 AM
Cerridius's Avatar
Engine: 305 TBI
Re: Flywheel question
Please let me know so my dad will quit yelling at me about it lol.
Old Apr 4, 2012 | 07:48 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
You should be able to use an LT1 flywheel no problem. As long as your 383 is balanced to work with a stock 1 piece RMS flywheel the LT1 flywheel will work just fine.
Old Apr 4, 2012 | 12:39 PM
Cerridius's Avatar
Engine: 305 TBI
I believe my 383 needs a external balance flywheel but it is a 1 piece. But aren't LT1 flywheels all somewhat external balanced, but the crank is neutral?
Old Apr 4, 2012 | 02:41 PM
LilSki's Avatar
Car: 85 Trans Am
The LT1s are external balance with the counterweight on the backside of the flywheel. Anything with a 1 piece RMS is externally balanced since the crank is missing a counter weight due to the way it is made for the 1 piece RMS.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
