Hydraulics
Car: 1992 Z28
Engine: 434 CI
Hydraulics
Anymore now where to get better then stock hydraulics for 84 camaro? I have a retrofit T56 and would llike to upgrade to a better hydaulics to make use of a better clutch ....
Car: `86 SS / `87 SS
Re: Hydraulics
You can go to the 93-97 stuff for a braided line and no meaningful changes to slave/master.
You can go to a Tick or McLeod master cylinder to get adjustability (or do it yourself with long nuts / threaded rod. Both those are larger bore IIRC.
If the stock stuff is working for you, it should work with a new clutch unless the pressure plate is obscenely higher lb rating.
88SS6SPEED
Nov 11, 2015 07:05 AM
topteam54
Oct 6, 2015 12:21 AM
