torque converter wont lockup
Old Apr 11, 2012 | 07:59 PM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I just finished my stealth ram installation and now my torque converter wont lock up...... the shifts are all fine and it goes into overdrive but the converter wont lock.....once the tv cable was installed on the stealth ram it was at a weird angle and is not straight on like it was with the tpi....could this cause it to not lock up??? Removing the TV cable is the only thing IV changed since my tear down and before it was doing just fine
Old Apr 11, 2012 | 08:04 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: torque converter wont lockup
not having your TV cable set correctly will burn your tranny up in no time. be patient, do it right.
Old Apr 11, 2012 | 08:14 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Apr 11, 2012 | 08:15 PM
Car: 1986 z28
Engine: 350 hsr
Its set and the shifts are good they are spaced out and the shift points seem to be normal bit only the torque converter wont lock up....I'm gonna check the plug on the. Tranny but I don't see how it could have come loose by Sitting in the shop
Old Apr 11, 2012 | 08:18 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
