leaking differential
Old Apr 12, 2012 | 01:22 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
My differential is leaking gear oil from behind the slip yoke. I replaced the front seal, but it is still leaking. I have read that you can fix this by putting RTV on the outer edge of the pinion splines. Would that work, or should I rebuild the rearend?
Some info about the rear end. My car is an '84, but the rear end is from a 95, both z28's. I know that the '95 is about 2" wider on each side, but all of the threads I read on this site indicate that it should be a direct bolt in. The rearend is in my garage and not under the car, which makes it much easier to work on.
Old Apr 12, 2012 | 02:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: leaking differential
Pinion seal replacement instructions below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
