26 spline axle question! PLEASE HELP!
I read the sticky post on the topic, but I need to know if I'm understanding this correctly. Can I swap a 28 spline Torsen posi unit, out of a 99 Camaro rear, into my 1984 (originally 26 spline) 10 bolt rear? I know I will have to add 28 spline axles, but can I do this without a problem? Also.....If I do this, is there an outer wheel/axle seal that is larger (for the 28 spline axle) that will work in my old housing? Thank you all ahead of time!!! Nice site!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 26 spline axle question! PLEASE HELP!
That is just plug and play, no seal changes needed.
They are the same size on the flange end.
On that note.....is there a 4.56 gear offered that will work on that stock 99 camaro carrier? I believe it was a 3.27 gear originally.........
I plan on 4.56 gears, 3 speed auto, and 28x9 slick
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
im sure someone makes a gear for it. im just wondering what kinda power your making with your engine. with the slicks you mentioned i wouldnt go over 400 hp with that rear end. get a 12 bolt or 9 in if your mill is 400+ hp. stock camaro rears are only 7.5'' and will only handle so much.
Like someone else said on this site. build up a 10 bolt and baby it or upgrade to a 9'' and pound on it without worry.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You can use the Richmond Gear ( and any other brand ) 4.56:1 7.5" 10-bolt gear set with the '99 Torsen in your '84 housing. The problem with this ratio is the grinding necessary to install the special cross-pin. And no, you can't have 4.56:1 gears in this proposal without also buying the special pin.
Genopsyde
Oct 7, 2015 08:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
