Governor Gear matching rear gear?
Old Apr 4, 2012 | 02:29 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
I have a trans from a 91 firebird transplated into a 1989 camaro body. Did not change the rear ends to match. I have the v6 rear end still, could there be a mis match with the governor gear causing my transmission to shift to soon at WOT?
Rear gear is a 3.27 or 3.23 I believe. Any help will be appreciated
Old Apr 18, 2012 | 11:42 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Governor Gear matching rear gear?
ALL governors use the same gear. Changing the WOT shift points is done with weights and springs, not governor gears.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
crazynights
Aug 21, 2015 06:53 AM
