Need help figuring out ring and pinion pattern - 9-bolt.
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
Hello.
I'm currently setting up a used set of 4.11 gears in my 9 bolt. Unfortunately it's my first time setting up gears, so experience is lacking.
I have tried various online searching, and I've read up on the subject prior to starting, but the pattern I'm getting is as far as i can tell a bit contradictory. On the drive side I'm on the outer part of the ring gear, tho, on the coast side i only get some small marks on the inner section.
Any advice on the direction to go here to get a pattern that fits the normal guides for adjusting a gear set?
Any input appreciated.
-Camarogeddon
-Camarogeddon
Car: `86 SS / `87 SS
Car: '85 Camaro Z28
Engine: 350 carbed.
Re: Need help figuring out ring and pinion pattern - 9-bolt.
That guide was more detailed than the others i have found so far, and included the information i needed. (i will need to decrease backlash as a starter.).
Thank you for the help
UltRoadWarrior9
Sep 2, 2015 08:24 PM
