Clutch slipping symptoms?
Old Apr 19, 2012 | 04:45 PM
1988camaro2.8's Avatar
Hello...
I have my 1988 camaro, 2.8l v6 sitting and was wanting to sell her. It was my car way back in high school. My dad has spent the money when needed over the years. Engines runs very strong. The issue I have is this...
When applying the gas and releasing pressure off the clutch pedal there is little to no movement of the car...it does get going with a good press of the gas pedal.
When driving...in every gear, when the gas pedal is punched the RPMs jump and the car doesn't. Sounds like a clutch to me? Will continue to search this site for more info. I love to see photos.
In the meantime would appreciate some feedback and maybe a link to step by step removal of transmission to access the clutch to replace it.
(there is no chance the system just needs to be bled?)
Where and what clutch should I purchase prior to removing the old one? Stock clutch is fine with me.
First timer here, and thanks in advance. Brett
Old Apr 19, 2012 | 04:54 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Clutch slipping symptoms?
I can help you a little bit on this one. The OE clutch should be fine if that is what the problem is.
Old Apr 19, 2012 | 07:36 PM
mjwadams's Avatar
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
I have fried enough clutches in my time (perhaps it is something I am doing? ), and it sounds like yours is fried. I would recommend bleeding it to see if it helps before you replace the clutch as it is a lot easier.
The stock should be fine unless you drive crazy like me.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
