RTV On 700R4 Pan
Old Apr 24, 2012 | 12:35 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
RTV On 700R4 Pan
Hey guys I am trying to find a general consensus on whether or not to use RTV on the pan gasket when I put my 700R4 pan back on. I am installing a 2600 converter and just serviced the transmission. I don't want the transmission to leak, but when I pulled the pan off there was no RTV from the prior service
Thanks for the help guys.
Old Apr 24, 2012 | 12:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: RTV On 700R4 Pan
just use a good quality rubber gasket. If its cork toss it !!
Old Apr 24, 2012 | 02:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
use the black GM gasket. Skip the cork. Skip the RTV. A bent pan should be replaced, not RTVd.
Old Apr 25, 2012 | 09:51 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Yep. First off make sure the pan is good and straight. Then make sure you have a good gasket. Neoprene or Duraprene I believe are what the better ones are made from.
Thats what I have always used and no leaks yet. (Only time I had an issue was due to a bent pan)
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
