Which trans?
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
Which trans?
im debating between a 700r4 and a turbo 350. any pros or cons on either? i gotta get rid of the turbo 200 i have. also which mods do i have to do for either of them?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Which trans?
700 is 4 speed 350 is 3. 700 has lockup 350 doesn't. 700 is standard equipment so easier install and parts.
Car: 82 Z28
Axle/Gears: 3.43
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Which trans?
TH350 is a near bolt in in place of a TH200-will only
need a torque arm mount kit.700 r4 will require quite
a few parts off a 700r4 f-bod for the conversion.
I have had both in my '82,liked the first gear ratio and
1-2 ratio spread of the 350 better vs the 700 and the
350 is lighter and a little smaller than the 700.
i do like the overdrive of the 700 and mine has been
tough and very reliable,my 700r4 from an '85 caprice
with shift kit and f-bod tail housing added.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Which trans?
And what do you want it to do? What will you do with the car? How much power do you have? How easy? What cost? The pros/cons of each trans need to be weighed against other factors.
Car: 82 Z28
Axle/Gears: 3.43
Re: Which trans?
I just rebuilt the 305 cfi and beefed up the guts. ill probably go with the 700r4 because what i really want it another gear. i just want some more get up and go and I'm tired of driving down the highway doing 80 and at 4500 rpm
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
