Rear end after engine upgrade
Old May 1, 2012 | 04:51 PM
whathasnt's Avatar
Is it possible to simply rebuild the rear end to handle more power vs spending 2000 - 3000 + on a complete rear?
I'm looking to up my car to 450 - 500 hp and around 490 torque and want to make sure the rear is up for it when done.
I see all kinds of options for new axles, and gears, and thought that it might be cheaper to just rebuild it.
Thanks for any info.
Old May 1, 2012 | 06:35 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Rear end after engine upgrade
By the time you buy all the upgrades for the axle you have, you'll be in pretty deep anyway, and still risking breakage. Search around and see if there's anyone who can help you fabricate a torque arm mount for a Ford 8.8" from a Lincoln Town Car. Then your biggest worry is the bolt pattern for the wheels.
Old May 1, 2012 | 10:49 PM
whathasnt's Avatar
Ok, thanks for the input.
I'm redoing the tranny first and won't be getting to the engine and rearend until sometime next year so I'm thinking I'll just change the gears to 3:73 for now so I can have some fun and deal with the rest when I'm ready to get the engine done.
Old May 17, 2012 | 07:51 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Replace it, I went through 2 rebuilds on my 10 bolt and it needed a 3rd when I finally replaced it w' A Moser 9'', expensive yes, but well worth it. I am pushing 500 @ the flywheel. The 10bolt had a girdle, auburn posi, moser axles and 3:73's w/ Tubular LCA's and a UMI Torque arm. It still would not holdup to abusive driving....
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
