Rear end with disc brakes
Old May 7, 2012 | 03:54 PM
bakerstreet's Avatar
I have a 92 camaro rs with rear drum brakes.
Yesterday i saw a camaro at the salvage yard with vin #8, that had a rear end in it that had rear disc brakes.
Can i get that rear end & just install it in my car?
If so, what else would i need to get from the salvaged car besides the rear end, brake hoses, calipers & rotors?
Old May 7, 2012 | 04:56 PM
89JunkerRS's Avatar
Car: '89 Camaro RS
Axle/Gears: 3.42, Open
Re: Rear end with disc brakes
I think you'll need the proportioning valve too when you swap in the disc brake rearend
Old May 8, 2012 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Whether the rear is a 9- or 10-bolt, the following info will be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Because of thread differences, the earlier combination valves won't fit your 92, so you'll need an adjustable (I'm assuming the salvage yard rear has 10.5" rotors and iron Delco-Moraine calipers, a set-up whose reputation isn't terrific here on TGO). The parking brake may be problematic as well, as your 92 won't have the tunnel-mounted adjustment piece.
If the salvage yard rear is 89-92 with 11.7" rotors and alum PBR's, the swap would be easy where the above issues are concerned--and generally much more desirable.
JamesC
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
