Dumb question
Car: 86 T/A GTA Rims
Engine: 350 Mild cam 750 holly
Transmission: Beefed 700R4
Dumb question
I just purchased a new 700r4 and the tv cable wasn't adjusted right... i took it around the block 4 times and attempted to do a burnout and failed. I was just wondering if i could have damaged the tranny at all from driving it without the right adjustment? The top speed i went was 30 at most.
Engine: 4++,350 & 305 CIs
Re: Dumb question
Doubt it.
What gears do you have in your rearend???
Re: Dumb question
good... rear ends stock and its been leaking for awhile the oil is everywhere.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Dumb question
Go to the
tvmadeez
site. Read it & watch the animation of how a TV cable and internals work.
It will tell how to adjust it.
Very informative as well as educational. It helps!!
tvmadeez
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Re: Dumb question
thanx i needed to know the answer to this quest. also I am going from tbi to carb and needed this thanx!
NinjaNife
Aug 23, 2015 11:49 AM
