speedometer wont work **HELP**
Old May 9, 2012 | 11:17 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So here was the issue the speedometer cable broke so got a new one however the connector on the guage end had to be chaged to fit the guage so pulled it of the old cable put it on the new cable got it tightened into the trans and the guage but it still doesnt work someone help please
Old May 9, 2012 | 11:25 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: speedometer wont work **HELP**
the green circle side goes to trans and the yellow to the guage which had to be changed to fit due to having after market guages
Old May 9, 2012 | 11:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Did you verify that both ends of the cable were seated correctly (into the gauge and snapped into place and at driven gear)?
JamesC
Old May 9, 2012 | 12:45 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
JamesC
How do i verify that there seated correctly and snapped into place and at driven gear?
Old May 9, 2012 | 01:06 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
What I used to do with my 82 was connect it yo the dash and feed it out through the correct route. After that I would either spin the transmission end of the cable by finger and have someone watch the gauge. Or I would lock a drill on it and lock the drills trigger on then check myself..
Old May 9, 2012 | 04:13 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Okay well i used my drill and got it all to work now my only issue is that the needle bounces around its not to bad and i can live with it but would like it steady heres a video of it
http://www.youtube.com/watch?v=Pwisn...ature=youtu.be
Old May 9, 2012 | 05:53 PM
JamesC's Avatar
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
