pulse vibration
Old May 11, 2012 | 06:36 AM
sonicwolf89's Avatar
pulse vibration
ok this just started after installing bmr suspension tube lower control arms with poly bushings.
cruising at highway speeds (65 mph) the rear end starts vibrating but its like a pulse and gets worse and more consistent at higher speeds.. its an 82 z28 with the stock rear end as far as i know.
any ideas on what it could be? its making me quite uncomfortable esp. when my son is riding with me. i retightened the lower control arms last week and it helped a little now its starting to get worse.
Old May 12, 2012 | 08:33 PM
Re: pulse vibration
well i figured i would start with seeing if the tires were out of balance so i had them rebalanced and it helped just a little. the axle shafts have a little bit of play in them. any one have any ideas?
Old May 17, 2012 | 07:44 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: pulse vibration
Check your u- joints for play, especially the front....
Old May 18, 2012 | 08:08 PM
Re: pulse vibration
i had replaced them about 4 months ago. i disconnected the driveshaft and spun the tire as fast as i could get it and it made the grinding sound from inside the differential. i think its the pinion bearing
Old May 18, 2012 | 09:30 PM
J91's Avatar
J91
Re: pulse vibration
bummer....
Old May 19, 2012 | 08:26 AM
Re: pulse vibration
yea especially since its really my only vehicle.. i can ride my motorcycle except for when wind gusts are at about 20mph.
Old Aug 8, 2012 | 10:02 PM
Re: pulse vibration
its the motor mounts... they have excessive play
InfernalVortex
Apr 20, 2021 11:31 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
